REMOVING PINSTRIPES
Just peel them off. They are just a sticker and don't leave any glue behind. Just took off pin stripes myself.
2002 Z/28
Bright Rally Red, Ebony Leather, T-Tops, M6, Hurst Short Shifter, Sport Appearance Package
Performance Mods: SLP Lid, K&N Filter, Flowmaster Exhaust, Bellows Kit (red), Ported MAF Ends, Lou’s Short Stick, CAGS, A/F Ratio Gauge, Drilled & Slotted Front Rotors, Strut Tower Brace, Panhard Bar.
Appearance Mods: White Face Gauges, Painted Front Grill (gloss black), Mobil 1 Oil Cap, Tinted Windows (50F/35B), Satin Black Taillight Panel w/ Red Reflective Concept Camaro Letters, '69 Z/28 fender emblems, Neon under car kit (red), ZR1 17" Wheels w/ 275/40ZR17's.
z24z28.cz28.com
2002 Z/28
z24z28.cz28.com
Same here, just pulled them off, came off without a problem, the pic in my sig shows them with them still on. Looks way better without them. Good luck.
Lori
My Z
35TH ANNIVERSARY Z28 ported throttle body
ported MAF sensor
Custom true cold air induction
Throttle body bypass
3"exhaust cutout
LS1 Bumpstop mod
K&N filter
[This message has been edited by BIGRED Z (edited July 20, 2002).]
Lori
My Z
ported MAF sensor
3"exhaust cutout
LS1 Bumpstop mod
K&N filter
When you first remove them, there will be a little residue left behind, it will come off with time, and washing.
1997 Red/w Black top Z28
A4/3.23's/ T-Top converted
K&N CAI,!TB, Flowmaster exhaust, cutout, BMR STB / SubFrames, Lowered
:rdered 2800stall/trans-go/cooler::
Best - 2.26 60'
1/4- 14.004 at 99.71 mph (with the t-tops off)
Best - 2.26 60'
I had pinstripes on my 93 Probe GT that I took off. Used a hair dryer and then some 3M Adhesive Remover to get the rest of the stickum off. Worked great.
This weekend I replaced my front bowtie -- used a hairdryer and then some Goof-Off. That worked just as well. I was a little afraid of the paint getting screwed up with that stuff but it was fine.
97 Z28 M6 Black
Moroso CAI, 1LE elbow, airfoil, TB bypass, 160 thermo, HPP+, LT4 KM, AC Delco Rapidfire plugs, Taylor Spiro-Pro wires, B&M Ripper, 1LE tranny mount, polyurethane front swaybar bushings, Borla catback WFO, BMR STB, red badging and custom red interior, chrome 17x9.5" ZR1s, Firehawk SZ50s, synthetic fluids throughout
97 Z28 M6 Black
my pinstripes dont peel off easy how else can i remove them?
http://camaroz28.cardomain.com/id/kev311
Use a hair dryer. They will come off MUCH easier that way. And if they leave any adhesive, do NOT leave it on. You can get it off. You can buy this stuff called RIGH OFF at your local auto shop or advance store.
It isn't too bad, just take your time
Re: REMOVING PINSTRIPES
the left side of my car has faded, sun baked dry pinstripes on it, i took the whole right side off with ease, but i have no idea how to get the stuff off, i have tried goo gone to saturate it, tar and bug remover, a hair dryer...
i can't get the sunbaked ones off, someone told me that i can use a lacquer thinner on it, and they should come right off, but i wasn't sure if this would mess up the paint or not.
i need help on this!!!! FAST!!!!!
Is nail polish remover good for removing baked in pinstripes? I have pinstripes on the left side of my car that are absolutely baked in. Does nail polish remover help take out any adhesive as well from stickers?
Originally Posted by kev311
what is the best way to remove pinstripes so you cannot tell that there was ever any?
I found out mine were painted on the hard way. I heated up the area with a hair dryer and picked at it with my nails... took some of my paint off too. damnit. Anyways, if they were painted on like mine, I used EZ off oven cleaner. I sprayed it on, wiped it off then rinsed with alot of water... didnt damage my paint. Maybe I was just lucky or something but I found that out by surfing the net.
NewsBot
09-14-2015 09:20 AM
RX Speed Works
09-11-2015 03:31 PM
