Reverse Indiglo overlay install help
Here is how I did mine, which uses the fog lamp wiring which is good since I always leave the switch on.... parking lamps or headlights on and the gauges light up.
Splice red wire from the inverter to the brown wire running to the fog light switch
Splice the black wire from the inverter to the black wire running to the fog light switch
It comes in one big sheet, so first I put the tips of the needles through the appropriate holes, the mph and rpm needles first, and then slided the guage face down over them until they're in place and the little needle stops/rests pop through their holes. Then you just carefully bend the face to get the smaller needles through, the face plate is flexible.
Sergio
01-27-2016 04:27 PM
12-17-2014 11:00 AM
