show me some slammed camaros
i want to see camaro that are lowerd via springs or coil-overs, i need to get an idea on what springs to use and what size drop i can get from each brand
here, you can check out mine as well. Its also sitting pretty low on Coil-overs. If you plan on lowering it, definatly get coil-over suspension, that way it will be fully adjustable. You can drop it 2 or more inches when cruising around, or if your at a show, just slam it to the ground. I put in Groun-Control coil-overs on mine (they are rather inexpensive), but if you want the best quality coil-overs, go with LG Motorsports and im sure that also Penske makes a great set as well (but more expensive).
I just have an Eibach Pro Kit on mine. Lowered the car 1 1/4 to 1 1/2". I drive my car nearly every day so I had to have some ground clearance.
http://www.aldersgarage.20m.com/images/RyanEnkei.JPG
Ryan
Ryan
Ryan
Ryan
http://www.sffba.net/members/jcamere/zinparadise.jpg
ChrisFrez
01-11-2015 03:47 PM
ChrisFrez
12-21-2014 09:47 PM
ChrisFrez
12-15-2014 03:09 PM
ChrisFrez
12-07-2014 06:01 PM
