To those who have removed side moldings...
It sounds pretty straight forward. Just basically heat up the glue with like a hair dryer and use some fishing line or even just dental floss I'm guessing will do the trick to remove the plastic pieces... Then I guess just continue heating up to remove any residual glue right??
I've been considering doing this for a while now probably gonna do it soon. But I was also wondering... Since I still have original paint, won't the areas where the side moldings were glued to be a different color compared to the rest of the doors/quarter panels?? Or not enough to really notice that much? If it will look odd I might just leave it the way it is now.
Thanks for the help...
Re: To those who have removed side moldings...
I've removed the molding on 2 blk z28 LS1's with no problems. easy to do and I didn't even heat up the molding at all. No color issues after removing or getting off the old adhesive. [IMG][/IMG][IMG][/IMG][IMG][/IMG]
You might have some residual glue after removing the molding, a soft cloth with rubbing alcohol will will take care of that for you. I think that was my very first mod on the Z since they were peeling and fading.
You may be able to tell where the moldings were since the unmolested paint underneath will be in better shape than the rest, but it's nothing a quick buffing won't fix. The only time you'll have an issue is if the panels had a half-assed respray where the moldings weren't removed. The only satisfactory solution in that case would involve repainting the affected panel(s).
Actually now that you mention it, when I took a quick look at the passenger side molding on the door, there seems to have been paint sprayed on (maybe after a minor accident?), because there is one spot where some extra paint had dried up on the molding. You have to look hard to see it but it looks pretty sketchy... Is this what you're talking about?? Because the new paint won't match the factory paint underneath?
squarehead
11-21-2014 08:02 PM
