TruFiber ss hood pic
they are called a trufiber hood, believe its like aftermarket auto warehouse
Bolted it up, and had to do some very small tinkering with the bolts in the holes, and it was fine from what he said. Said it was pretty straight forward
Hoods are easy once you know how to align it. Bolt the hood on the brackets. Live the front screws finger tight and back ones little tighter so the hood can be moved. Close the hood easy and latch it. Use a tool (((something wide, strong but not too thick))). Place it between the hood and fender and make the space as needed. Remember to use a peace of cloth so you don't scratch the paint. Once everything is aligned have someone come and unlatch the hood while you have some weight on the hood pressing down to prevent it from jumping up and shifting.
Once it’s opened tighten the screws and you’re done.
