What Should I DO!!
What Should I DO!!
I am finally getting my first f-body. i have 2 chooses,
i can get a 94 camaro with body kit,new hood, alarm, and stereo
or i can get a 98 with lower miles and nothing esle done to get.
the 94 is 5,500 and i will be doing a front end swap, and can sale the body kit and hood.
and the 98 i dont have to do the front end swap. the 98 is also 6,759
what would you guys do. cheaper car with extra or newer car with low miles
Thanks alot!!!!
Thanks alot!!!!
98 all the way..... not only will it be much newer, the 98 will have an extra 40+ hp, which makes a big difference... the 3.8l is a much better engine then the 3.4, no offence 3.4 owners.....
plus wouldnt u want a customized car you did yourself instead of having someones work?
Definately the 98: has some "revised parts" like the motor, window seals, drl's and the newer front end (I really like drl's, i put them on my bird look at sig), low miles are a plus, and it has most likely been beat on less just b/c everyone who i know w/ a body kit beats the **** out of their car. <---totally opinionated
