What tires to get for 18" torque thrust II's?!
My boss knows a guy that works for AM Racing. He can get me 18" TTII's for $150 each! But before I buy them I want to know what kind and size rubber to put on them. I am clueless when it comes to tires. I just know I want them to be wide/low profile and good quality. Also what is the best place (cheapest) to get them? I plan to put the 18x8's up front and 18x10's in the rear. Any help is greatly appreciated.
You can use 285x35x18 rear and 275x35x18 front or 275x35x18 all around.
93Z28 Red/Blk A4 /STB/lower springs/JBA headers/Borla cat-back/285x35x18Nitto/Boyd Coddington Smoothie2 18x10//Random Tech cat/underdrive pulley/K&N KIPK/TR55 plugs/MSD 6+ digital/AFPR//BMR LCA,Panhard rod,SFC,LCA bracket/SLP torque conv/B&M tranny cooler/1LE sway bars/optima batt in spare tire well/Meziere H2O pump/HAL shocks/GM 3.73/TA girdle/Dennys HD drive shaft/Baer Track Kit brakes.
It differs in diameter and tread width. Look up at www.tirerack.com for specifics.
You can run 275/35/18 on all 4 corners. That is the setup that I went with.
http://camaroz28.cardomain.com/id/whitedeathls1
1999 Sebring Silver Metallic Z28, M6 T-tops
Cosmetic Mods: GM SS Hood, 18" Y2K Chrome Corvette rims on Kumho Ecsta 712s in 275/35/18ZR, Corvette FRL covers (More to come!...)
HP Mods: Borla Catback, Granatelli MAF, Whisper lid with K&N, Free Ram Air, Superior 4.10s w/Ratech Crush Collar Kit, TA girdle w/stud kit, HPP3 w/160 t-stat, MMS ported TB, EGR and TB coolant bypass, ASP crank & Alternator pulleys
Suspension Mods: KBDD SFCs, Spohn LCAs & Adjustable PHR, Addco 32MM front and 1LE rear sway bars, BMR STB, Eibach Pro-kit
Extras: B&M Ripper shifter with RK Sport Satin Finish shift ****, Mobil 1 filler cap.
320rwp, 325 max torque on MMS Dyno jet!
R.I.P. 1998 Z28, 1/23/2002
<font face="Verdana, Arial" size="2">Originally posted by Johnny I:
...Also what is the best place (cheapest) to get them? I plan to put the 18x8's up front and 18x10's in the rear.</font>
I went with Yokohama AVS dB 275/35 all around to match the factory diameter - on the 10" wide rim they will look good and wide. They are a quality tire and second cheapest to the Kumho's.
DaveH
275= width of tire (more looks better)
35= sidewall amount (less looks lower pro)
18- RIm size (obviously)
-SpeC
94' Z28 Purple Pearl Camaro
A4 3.23's,K&N CAI,Borla Cat-Back,Hi-Flow Cat,JET Stage 1 Chip,JET Airfoil, Hypertech 160° T-Stat, KYB Shocks,Eibach Pro-kit Springs, Various Appearance modz,17x8 Boyd Coddington "Smoothie" Rims & Nitto 555 ZR's 255/45/17 *Near Future: MAF*
Kenwood 4011s Deck, 4 Polk Audio Ex602a 6 1/2 in speakers,
-SpeC
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
