Who would be interested in a different headlight assembly for 93-97 Camaro's?
#406
I'm not sure what you mean by going over the edge but i have an aftermarket hood and it has a thicker edge then stock so maybe you see that but it is pretty flush all around,unfortunatly they never fit a 100% perfect! Maybe i can take a better picture of it!
#410
FocuzTech, I think with any of these aftermarket lenses it will be a less than perfect fit. With owning a set at one point in time myself, I can tell you that they may get you a good start, but I wouldn't base the design entirely off of them. You will probably need to tweek them a bit to fit up to your high standards.
#411
#412
If we have to design and create a lens and mold from scratch, it will increase the the duration and cost of this project. If we can use something that gives us a rough benchmark, then we can start from there and refine. This makes things much easier and should keep initial project costs a tad lower.
Good luck as always, and thanks for keeping us in the loop. It always puts a smile on my face to know that progress is always being made
#413
I'm sure the debate is long since over with, but go with something along the lines of this: http://www.seidling.info/images/fahr...peramerica.jpg
#414
#415
Is there any time frame at all to expect these headlights? I need to know when to start saving my loose change so the woman does not **** a brick when I tell her I am about to drop $600 on headlights for a car i never drive.
#416
I believe the latest word was that they should be completed sometime this fall (subject to change I am sure).
#419
It's about the only thing I would change about my 95Z appearance wise. That and the headlights just don't seem to put out enough light. These new headlight assemblies will undoubtingly take care of both of those issues.
#420
