window tinting yourself???
#17
Originally posted by WhoBetter?
why don't you just have it done within the law like your supossed too? I mean tinting is legal, you just can't completly black it out. so just get the legal stuff and accept it.
#18
The sides are pretty simple, the back will take TONS of practice to do satisfactoraly in 1 piece. I can do it OK myself, butI'd rather pay somebody else to do it because you get a lifetime warranty on the good stuff. (Llumar or Johnson)
The other guy said it pretty goos as far as to cut it out on the outside. All I have to add to it is to leave it about 1 cm long on the bottom, so you can tuck it into the rubber weatherstrip and it wont get caught on it when the window rolls down. And use a razor to trim it about 2 MM in from the edge of the glass once it's on the inside. This keeps the edges from peeling.
And buy the good TINT!!! Dont put that S$%T from the parts store on your car! It looks purple in no time, then gets air bubbles and peels off in the sun. Go to a shop that sells window tint, preferally llumar, they will probably sell you some for 2$ a foot. It costs 1$ a foot for them to buy it on a roll... if they tell you other wise they're lying.
#19
i tired 5% and it kept wrinkiling around the sides
but you are only supposed to heat in one direction... up and down (top of window to bottom, bottom to top) thats why you want to get the wrinkles towards the top so they are vertical. that way you can heat them the correct way!
hope this helps! let me know if you have any more questions. its kinda hard to explain!
z28cam1993
09-09-2015 04:08 AM
07-10-2015 02:23 PM
