Autocross Cam and header clearance questions
I mainly autocross my car and am looking to add Hooker LT's or 1 3/4" SLP shorties and a cam in the next couple of months. My car has the Eibach Pro-Kit and I'm wondering if hookers will clear-anyone know?
I know there are a lot of cam threads in LT1 tech but I'm not a drag racer and I need area under the curve and to make lowend torque since I autocross. I'm going to be using stock heads since I don't think I'll have enough money left over after converting optisparks.
Here's what I'm considering...
1) LT4 Hot Cam
2) CC305 220 / 230, .510 / .510 114 LSA
3) Comp Cams "Extreme" LT1 Camshaft, 218 / 224, .495 / .502 112 LSA
4) Comp Cams "Extreme" LT1 Camshaft, 224 / 230, .502 / .510 112 LSA
Opinions appreciated.
1) LT4 Hot Cam
The Hooker LTs sit really low. A buddy of mine with a stock(suspension) '96 WS6 had troubles everywhere he went with his, he even needed boards to get over the lip going into his garage! You might want to take a look at Dynatechs, if you weld the collectors on you shouldnt have a problem with leaks.
I think that the CC305 and the 224/230 cam would have similar powerbands however the 224/230 would give you a little more lope at idle. I belive either would be a decent choice.
I am currently trying to find a way to run a Y pipe on my car so I can sit it down a little lower myself. I'll see what I can come up with and post up some pics when I get it done. Anyone else have ideas??
Note on the DynaTech headers for LT1 cars, if you have any sort of T pan like the Canton RR pans they will not clear it. Only true long tube headers I have found to clear any 'big' pan are the Hooker Long Tubes.
I had the LT4 HOT cam in my car with stock heads and everything just with MAC shorties, 4:10s and a 3.5" mufflex and it ran 13.5s at 106.5mph. The suspension and street tires didn't help ETs to much but it did have a lot of power and drove pretty good from 3000-6500 or so
I don't know about the XE cams, my friend is running the 224/230 but he drags the car and its an auto so I'm not really sure about it.
