Autocross and Road Racing Technique There is more to life than a straight line
max tyre width on a 8" rim??
Old 05-05-2003 | 04:08 PM
jagsy's Avatar
Sorry to ask, but I am a novice.
What is the max tyre width on a 18 x 8 rim?
Thanks from the UK.
Old 05-06-2003 | 02:30 PM
sgarnett's Avatar
If you've got a tire in mind, you can look up the approved rim widths on www.tirerack.com.
245/40-18 looks reasonable (from Bridgestone S-03 specs).
Old 05-06-2003 | 06:00 PM
Dr.Mudge's Avatar
Profile changes things a little, but I have 255s on the rear of my car and they really should not have been put on, oh well. Stick with a 225-245 IMO.
Old 05-07-2003 | 10:38 AM
sgarnett's Avatar
Yes, 225/45-18 or 245/40-18 should work.
For the street I'd use the 245/40 if for no other reason than they might protect your rims a LITTLE from LIGHT brushing against a curb. They'll probably lok better too.
The 225/45-18 might actually handle better on the front wheels, but I wouldn't use them at the rear and mixing would eliminate the option of rotating the tires.
Besides, with the 18" rims you're going to have very little sidewall compliance anyway, so the extra sidewall flex of the 245/40 may actually improve grip a bit.
G-BODYT56
01-15-2022 12:14 AM
IndyZman
10-22-2015 03:17 PM
Formula Steve
09-19-2015 09:48 PM
rvonsternberg
09-14-2015 12:58 PM
scottcba1
09-08-2015 10:52 AM
