Accessory Wire
Accessory Wire
damn... electrical problems in my car.... i've had a problems with my cars power windows and locks so the dealer put a peice of metal to bypass one of the 30 amp fuses in my fuse block...
now i can use my power windows when the car is off and the key is not in the ignition.
Tried installing an aftermarket head unit the other day... the damn thing turned on as soon as i connected my negative battery cable and doesn't turn off when i turn the car off...
so i'm guessing the window problem messed up something else in my car....
so i'd like to try to use the accessory wire and connect it to the 12v ignition wire on the wire harness...
just like to know where this wire is and what is looks like....
heh... i've only had this car less than a month and i'm already running into problems....
another thing... is now my power locks are acting really wierd... something when i shift from drive to park, the doors lock and then unlock thmeselves, or when i turn the car off they do the same thing... sometimes when i try to lock the car with the remote... they lock and then unlock themselves....
carguyshu
01-22-2017 11:19 AM
Henson071
05-04-2015 12:23 PM
