Bose stereo aftermarket HU question
I had my Pioneer head unit with stock BOSE system rewired due to the speakers were cutting in/out sometimes and the rear speakers by the rear seats did not work at all. Once i got it back all speakers work but the bass isn't as good and 80% of the sound comes from the speaker in the trunk. when i change the fade to the front it's really quiet even turned up. What did they do wrong? I take it back Thursday and have already paid the shop $130. It sounded better before when the rear speakers didn't work! WTF?
Well your bose system was a 3 speaker setup and your HU is a 4speaker setup. so if they wired all door and panel speakers there would be no wire left for the sub in the trunk. Check to see if your sub is now hooked up maybe they didnt connect it-this would be your answer to your bass reduction. I had the bose system in my car and i removed it and had panel and door speakers and i get NO bass from them. Its probably the enclosure setup or something or me lol. Have u opened up your side panels grills to see if there was speakers in their? because from the stock bose systems dont include side panel speakers. When they rewired it did they bypass the bose amps?
Wow, lots of bad info in here.
http://shbox.com/1/bose_wiring.jpg
The Bose system is a 5-speaker setup, with the fifth speaker incorporated into the amp in the back. The 2 rear bass speakers are directly powered and amplified by the amp, while the front 2 only receive power from the amp, and have their own individual amps (attached to the speakers).
The amp has an on/off signal wire that tells it when to turn on. It takes the 2 signal wires for each rear speaker from the HU and amplifies them, then sends them to the speakers.
When you wire up an aftermarket HU, you wire it up just like a normal 4 speaker system, except you hook up that amp signal wire as well.
So if you wired from the HU directly to the speakers, they are going to sound very weak, because you are bypassing the amp. You probably already blew them, so I would replace them.
F'n1996Z28SS
08-23-2023 11:19 PM
CamaroHeed
03-18-2020 09:50 PM
