HELP! Having trouble with Alpine HU and Sub
Old 07-18-2002 | 12:29 PM
Rino1313's Avatar
Post HELP! Having trouble with Alpine HU and Sub
I just got done installing my Alpine cda-7875 HU, and there seems to be a problem with the bass. It's on ALL the time, real low and mellow like...and it doesn't change, no matter how high/low you set the bass. I checked all my wiring, and it seems to be correct. It's got 4V pre-amp output for the subs. The amp is a fosgate 250a2. I was using it before with my stock HU and some of those PAC controllers, and everything worked fine. Now, I am using RCA's straight out of the HU back to the amp. Everything for the amp is hooked up correctly. Any ideas what the hell could be going on? Once again, even when the volume is at 0 on the HU, there is a very low mellow hmmmmmm coming from the sub.
HELP!!!
Everything else works fine, incl. head unit, and all door,rear speakers.
Old 07-18-2002 | 12:30 PM
Rino1313's Avatar
Post
Sorry about the double post...Didn't think the 1st went through.
Old 07-18-2002 | 05:16 PM
DrMilhouse's Avatar
Post
If you unplug the RCA's from the head unit, does the sound go away?
99 Z28 LS1 (broken with 383 replacement in the works) M6
stereo pics FOR SALE!!!
Moderator at CamaroVsMustang.com
Send while you can!
Ericksd
01-20-2016 06:07 PM
football4life
10-04-2015 07:48 AM
ZXXVIII
09-01-2015 10:13 PM
Schul365
08-22-2015 10:00 AM
surreybrad
07-05-2015 10:36 PM
Quick Reply: HELP! Having trouble with Alpine HU and Sub
