Hooking up the battery to an Amp?
My Question is what is the best way to hook a batery wire to the amp? I would rather not come directly from my car batery to the amp is there another way, mabey something to split off of?
One more question is it that difficult to hook up a couple of subs with the bose speakers and an aftermarket HU?
-mike
-mike
If you use one of those side post adapters to connect your power wires to the battery check to make sure that the threads aren't too long. I cracked the battery casing on 2 different batteries before I figured out what was causing it. The threaded portion is too long on some of them and bottoms out in the battery connection.
here's what I did
http://community.webshots.com/user/pauln64ss
GusarskiSS
Exhaust System
09-02-2015 03:51 PM
