Monsoon radio and amp help
Old 08-24-2011 | 01:22 PM
sutherncountry's Avatar
Question Monsoon radio and amp help
I have a 98 chevy camaro with monsoon radio and amp. I know the radio works the speakers in the main back and the amp work the 4 in the front and back seat. However, the two in the front doors do not work, and the one behind the drive side in the backseat does not work. The one behind the passenger in the backseat works.. Looked up the wiring diagram for radio and tested the out put wires and they worked fine. Also the passenger front speaker will buzz, then go away, buzz and go away. Kinda weird. Any ideas?
Old 08-30-2011 | 03:10 AM
L.dookie's Avatar
Re: Monsoon radio and amp help
bad amp maybe? combination of bad amp and speakers. how did you test the wires, are you sure your head unit is puting a signal out to the amp for those channels.
nosliw
03-09-2016 04:56 PM
Bigfatrat
Parts Wanted
10-16-2015 04:48 PM
football4life
10-04-2015 07:48 AM
Rod Bender
25
09-16-2015 01:47 PM
Bxlt1
09-10-2015 08:16 AM
Quick Reply: Monsoon radio and amp help
