please help with hu
Old 08-10-2002 | 12:22 AM
nothingeined's Avatar
Question please help with hu
okay i have a sony explode cd player and just a regular 12"sub connected through the rear speaker. i dont know much just wanted to see if the sub worked. it did but whenever it is loud the decks lights tend to dim in and out when it thumps. i dont have an amp to it just the two speaker wires spliced to the rear. do i need an amp or something to stop that? thanks
Old 08-10-2002 | 06:40 AM
LS1 RULZ's Avatar
Post
If you want to have a "real" subwoofer setup in your car you have to have an outboard amplifier to run it properly. Even then you may run into a "dimming lights" problem. Adding a stiffening cap may help this problem or it may not. It depends on the current demands your stereo is placing on your car's charging system. In that case a new high output alternator is in order.
Old 08-10-2002 | 08:48 AM
Post
thanks a lot. sounds pretty complicated.
Old 08-10-2002 | 08:53 AM
LS1 RULZ's Avatar
Post
It may sound complicated but it really isn't all that tuff.
