Speaker System, Yeah Im Clueless...
So I want a speaker system in my 95' Camaro Z28 Convertible. All this includes 2 Subs, an Amp, a new Radio, and an Enclosure... at least thats what ive heard I'll need. I have $500. HELP ME; what should I get?
I listen to rap/hip hop mostly and want some thumpin' bass!
Re: Speaker System, Yeah Im Clueless...
well, having a convertible does not help you any. they muffle the sound some and there is less room for an enclosure. $500 is doable but a little tight.
If your happy with your door speakers then all youll need is a mono block amp. You will want to look at your rms ratings not peak ratings as peak ratings mean next to nothing. If you want just a little thump to cruise around too you should be good with 2 decent 12's capable off around 150 to 200 rms each. As well a headunit to me is always the first step but it is not necessary especially if your on your budget.
A convertible does not necessarily muffle the sound, what it does is leak pressure. So in turn you loose decibels (DEEBEEEZ lol).
If you wana cut down on price a little then you can make your own box, get a friend to help you and measure out where you wana put it, get some Medium Density Fiberboard, wood glue, and wood screws, and build one. thats what i did, set it down in the compartment in the hatch (i dont got T-tops). I may be able to get some pictures of it if you would like
the trunk is totally different in a covertible. I dont even know if the thunderform style box would fit unless specific for a vert. You can build one yeah, but just know most of what you see for coupe models probly wont work.
U can get a box for 100 at amazon
two kicker cvr for around 200
a good amp for around 200
memphis wires for 100
soo a good system for 600 bucks
PM me for any questions
Brad122470
08-02-2002 09:55 AM
97QuasarBlue3.8
07-22-2002 10:09 AM
