Is the speaker wire length important?
Does the length of speaker wire matter or make any difference, if so would you want it to be longer or shorter?
93 Z28 Patriot Red A4
Well, look at it this way.... every wire has a resistance per foot, that means every foot you add in length will add X ammount of Ohms. Typically in speaker wire it's very small but can add up, especially with High power systems, and too small wire.
If you have large enough wire for your speakers the length doesn't really matter that much.
Mike
1997 Formula WS-6, 1 of 473
Mods: P&P MAF, Pro-5.0, SLP LT4 Clutch, 200 Amp Alt, TB Bypass, !AIR, !CAGS, 160 therm, CSI WP, PS Cooler, GMS STB, Cutout, TCI LineLock, ES Swaybar/Trans/TA Bushings, 5%R/20%S Tint, Painted Calipers, Custom Clear Tail Lights/Corners
http://camaroz28.cardomain.com/id/97formulaws6
Mike
CobraEatr
07-29-2002 12:46 PM
