1981 z28 air induction
How does the air induction on the hood work? I bought a 1981 camaro z28 and the air induction does not work. I have 2 wires hanging down one orange and one black. Where do the wires go? The shop manual doesn't have it in it. Any leads would help.
cowl hood
the orange wire goes to a throttle switch on the carb,and the black goes to ground.if you mare missing this switch you can use one that is supposed to be used to accuate nitrous at w.o.t.(wide open throttle)you can easily modify this switch to open at 3/4 throttle.look in the nitrous section of summits catalog.
You are right, Eric. The air induction door is activated by a solenoid, which gets its signal from a switch on the gas pedal arm. When you floor it, the switch grounds and the solenoid opens the air induction door. Its the same for both 1980 and '81. I've had 2 1980 Z/28's and they both had the same system as my buddy's 1981 Z/28 (which he bought brand new in 1981 and still owns).
Dave
Dave
F'n1996Z28SS
08-23-2023 11:19 PM
BM93Z
08-22-2002 02:45 PM
