ceramic-coated headers
If anyone has put a set of aluminum heads on a SBC in a 74-81 Z28, could you help me with what type of headers, cerama-coated or regular, you used? Having trouble because of the D-shaped ports on the GMPP Fast Burn Heads.
I have hooker super comp 1.75" headers on my 79. I have edelbrock performer rpm aluminum heads on the motor.
12 second 400 sm blk 79 Street Camaro. 68 camaro with 400sm blk street/strip project
http://www.wilsonmotorsports.net
[QUOTE]Originally posted by ahotrod79:
[B]I have hooker super comp 1.75" headers on my 79. I have edelbrock performer rpm aluminum heads on the motor.
what gaskets do you use with those headers?
Thanks,
Brad
70 RS, 327, T10, 4.11's
99 formula, m6,
Thanks,
Brad
99 formula, m6,
I am running 1 3/4" Headmans on one car and 1 5/8" Dynomax on the other. Both are 81 Z's and both have Dart heads. I remember seeing that Headman makes headers for 70-81 Camaros that are for use with the D port heads. I will try and find the part # .
1981 Z28 12.97 @ 103.91
355ci.,272 HMV Crane am,Dart 200cc Iron Eagles,Performer RPM,750 Vac. Sec. Carb, 3.42 gears,2800 stall.
1981 Z28 T-tops
355, 215CC Dart Iron Eagles, 284 xtreme energy cam, Victor Jr. intake, 750 Double Pumper,3500 stall, 3.42 gears NOS Cheater. No times yet
http://members.tripod.com/gainesvillepower/index.htm
1981 Z28 T-tops
Brad,
I used the gaskets that came with them. Mr gasket and felpro make gaskets for them, but I haven't had to get any new ones yet.
As long as you have the correct gasket to seal the ports, the header doesn't know what shape the ports are.. the exhaust ports on those heads are so small, I would think that any header with a primary of 1-5/8" on up would fit them..the outside measurements of the gaskets are pretty much the same for standard bolt pattern headers...
Texlurch - 68 Camaro (Just a little ol' LT1 with a Hot Cam, I SWEAR
" a little spray never hurt anyone, spank you very much!"
or the old standby:"I came here to race, not sell real estate. You ain't scared, is ya?"
Thanks guys for the input so far. Texlurch, I think you hit the nail on the head. We were unsure about what you said be it makes total sense to me now. I keep you guys update when this ZZ430 goes in in the next couple of weeks.
