Need Help!! New
Need Help!! New
I have some questions i need help with. I have a 1975 Camaro my dad gave me sometime ago that was his first car. It came stock with a V6, i want to take the motor out and put a 383 stroker motor im getting from a friend. I have a 400 turbo transmission in it now and a rear end out of a 1970 monitcarlo 10 botl i believe. Whatelse am i going to need to do i know motor mounts, but what about springs, brakes, calipers, steering? what all do i need to change out here not quiet sure. Any help would be great. Thanks
Definitely going to want to change out the brake system. this swap makes the car heavier. Just like with a 3rd or 4th Gen you need to do that. Also you'll probably want a bigger radiator as well as fans from an 8 cylinder car. the rear should handle the power fine but check it over to make sure.
