i ma buying a replacement pcm, will a buick roadmaster pcm work?
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
i am buying a replacement pcm, will a buick roadmaster pcm work?
just wondering if a 94 buick roadmaster pcm will work in my car?
thanks
taner
thanks
taner
Well i am assuming that your car is a 94 or 95? If it is, it should work. the safest way would get the service# off the PCM. if the last 3 digits are xxxxxx051 it will work.
94/95 F-bodies shares the same PCM as B-Bodies.
Kevin
Kevin
Taner, here is a break down of the interchange for a 96 PCM. This is right off the computer I work off of everyday. You can trust it. Good luck
ENGINE COMPUTER ** 590-04208 ** 09/24/02
15:01:54
Camaro '96 Elec Cont Module (ECM); 8-350 (5.7L)
Caprice '96 Elec Cont Module (ECM)
Corvette '96 Elec Cont Module (ECM); (8-350, 5.7L)
Firebird '96 Elec Cont Module (ECM); 8-350 (5.7L)
Fleetwood '96 Elec Cont Module (ECM); (8-350, 5.7L)
Impala '96 Elec Cont Module (ECM)
LeSabre '96 Elec Cont Module (ECM); 8-350 (5.7L)
WHAT NEXT? _____ <cr>=main R=relist D=display inventory NOTES=user notes P=print
15:01:54
From: Stationed at Camp Lejeune, N.C. (But Going Home SOON!)- From New Jersey
Where is the #
Kevin
Kevin
It is possible that GM's service tag is not there, its a small rectangle white sticker. Some times the sticker looses its "stick" and they peel, or fall off. The service# tag is on the outside case, not on the inside.
The service # is at the bottom of the tag. If the tag is not there, there is an indication inside the PCM. But that means taking the "clamshell" apart.
thanks guys !
i got a 94 computer from a local yard. came out of a six speed car, already on it's way up to be flasahed.
this way i have a backup
What is the indication
Well i guess the question would be, when you say "flashed" are you meaning stock form, or flashed for your mods?
GM can flash your PCM with a stock calibration- But it is pricey, plus you have to have the PCM installed in the car.
Aftermarket "flash" or programmed- There are tons of these scattered about, majority of these have good reputations. Some are better than others. Seems pcmforless( www.pcmforless.com)is popular, and customers seem happy!
Re: What is the indication
Originally posted by dayusmc
How can you tell buy looking inside?
"T-side" and "E-side" and each side has its own flash chip. If both sides have an 28F512 its a 94/95 PCM. If one side is a 28F512 and the other is 28F010 its an 96/97 PCM.
Kevin Carnell
Engineering Team
FAST-Fuel Air Spark Technology
901-375-3487
www.fuelairspark.com
at the engine builder...
i sent it up to Agostino to have my original 396 program dumped into it. i have tunercat but have yet to load into my laptop and use it. first i have to learn how to use it
