losing 1st and 4th after tune
Have a 95 z28 with 4l60e a4... Never had any issue with transmission losing 1 and 4 gears till I was tuned.. I have tried replacing the 1-2 and 3-4 solenoids no change.. I can start off drive up through all 4 gears and stop 2times and on 3rd start when it shifts goes directly to 3rd gear (limp mode)... Tune was to set f/a ratios for my cold air intake.. Shaved heads.. Advanced timing for 93+ octane.. Removed a.i.r.. A/C... Any traction control deleted (to best of my knowledge it never had TCS)... And tcc lockup in 2nd and 3rd gears.. Anyone ever had similar issue? I have taken the car to Chevy dealership and no codes show up. I have a free retune with this guy but want to make sure the issue before I waste the retune.. Any help would be much appreciated
Re: losing 1st and 4th after tune
Did the Chevy dealer realize he needed an OBD-1 scanner with the correct adapter plug. There are a number of transmission codes that do not turn on the SES light.
OK so I took it back to a different dealership and watched them read the codes nothing.. Even took one of the service guys for a ride to show exactly what it does.. Lost 1 and 4 and he connected the scanner again while car was running still no codes thrown
Sent from my SCH-I545 using Tapatalk
OK so tonight I unplugged the PCM and cleaned the maf sensor.. Put it all back together and everything worked fine until I was stopped and floored it to see what would happen... I must have started and stopped 20 times befote nailing the throttle.. The car didn't seem to want to shift outta 1st but finally did but very high rpm.. And then went back to 3rd immediately.. Thus I'm back into limp mode again.. Is it possible that the tune has too high rpms for 1st causing it to go into limp mode?
F'n1996Z28SS
08-23-2023 11:19 PM
carguyshu
01-22-2017 11:19 AM
10-31-2016 11:09 AM
