LT1 96 Tune and fic or tune out trouble codes
Old 07-31-2007 | 04:34 PM
El Eve's Avatar
Hey guys, I have been in the the forums in and out am a student so i have lots to read .. nonetheless i make time to inform myself about my hobby . I have a 96 Z28, can see in my sign the modifications that i have done to it at this point . I am very aware that i need a tune. it seems to me that the car is running rich, I have been ignoring the Check engine light for a while not and well i think its time to get it done. I have added headers and seems to me that I have leaks just before the cats, I will get that taken care of this weekend.
I got these codes: P0133, P0153 ( sensors rich, or too lean, maybe the leaky connection is giving me this) I change the O2 sensors two months ago,
Also i got a p0300, misfire, going to check that aswell, since plugs were change about 3 months ago with ngk nt55r IX,
then i have p0336 ( faulty crank position sensor) ,
p0400 and a p0443 which i believe are due to a bad egr silenoid, I just order that from autozone along with the crank sensor.
So my question is, should i just return the two parts and send my pcm to get tune for all the changes that i have and have them disable my egr system, also i heard of people disabling the crank position sensor aswell.. whats my best option. i really dont need to be emission legal , I will leave egr system on for now, until i get long tube headers. I just want the best value solution. . Remmember am a student and... well can't fork out too much $$$$ i got a job but still does not allow me to live well and let my car be how I would like. N-eways:
Egr silenoid and crank position sensor was 70 dollars ( which i can return)
MADz Tune performance tune is 150.. so technically i need only 80 more dollars to have a tune and get all that other s**t fix instead of 150 plus 70 right?
What's do you guys think is my best option???
I am a Do it YourSelf type of person unless i have no really knowledge such as welding exaust pipes.. etc.. any ideas???
Thank you for all of your help
DirtyDaveW
12-01-2016 05:37 PM
David Dorris
01-17-2015 08:10 PM
InfernalVortex
01-17-2015 09:35 AM
A's 91 Z28
01-11-2015 10:58 AM
97FormulaWS-6
08-05-2002 05:15 AM
Quick Reply: LT1 96 Tune and fic or tune out trouble codes
