18" hurt 1/4 mile, how much?
Not enough detail and way too general of a question to accurately answer. The heavier the rim/tire combo the slower it is. 18's are often heavy. A taller sidewall is good for launching as opposed to ashort sidewall. However a longer rollout can help ET's.
It's been awhile but I believe stock '97 painted wheels run about 19-19.5lbs each. My C5 wheels weren't much different than my stock wheels, the 17s weighed exactly the same as the stockers and my 18s out back were about 21.5lbs each.
What you should be more worried about is how much the tire and wheel weigh compared to stock. Tires can vary by manufacture as far as how much they weigh. It can be +/- 5lbs (each) from one manufacturer to the next! Wheels play a part in the weight, but tires can play an even bigger role.
