4000 Stall and higher guys.
Old 05-02-2005 | 12:13 PM
gabez28's Avatar
I was curious what you guys with a 4000 stall and higher launch at. I currently have a Vigi 3200 and I launch about 2000rpm with the stock 10 on et streets. I'll be switching to a 4000 stall @ the end of the month and wanted to get some suggestions.
Old 05-02-2005 | 12:27 PM
Ken95Z28's Avatar
Re: 4000 Stall and higher guys.
Anywhere from 2000-2300, I have a 4300 in mine.
Old 05-02-2005 | 03:09 PM
Stephen 87 IROC's Avatar
Depends where your peak torque curve is. It's best to launch at or just below the peak torque to get the most torque to the wheels during launch. My converter stalls at 5700 on the transbrake but I only launch at 4500 with a 2 step. Launching at a higher rpm doesn't do anything for me. After I launch, the converter instantly flashes to the stall speed.
Old 05-02-2005 | 03:53 PM
shady93z's Avatar
i have a 4500 with a th400 and i launch off the barke at 4000. i have a cam only lt1 and with this set-up i went 2 tenths faster compared to my 700r4 with a 3000 stall i had last year. i expect to gain even nore when i spray the car.
Old 05-02-2005 | 07:27 PM
Projectz28's Avatar
Moderator
2400-2600 depending on track conditions.
Old 05-03-2005 | 07:24 AM
Derrick Redd's Avatar
2,300ish with my old 3,600 stall. Haven't been to the track yet with the new 4,200, but I'd say 2,500-2,800.
Old 05-03-2005 | 10:05 AM
LT4383's Avatar
2200 launch stall, flashes to 4000 at WOT. The 2200 stall netted me the best 60ft. time, so far.
Old 05-03-2005 | 10:18 AM
LS1_03's Avatar
Are you putting in a built motor with this 4000 stall? IMO, it's too much for a close to stock power car. You'll probably launch good and hard, but you'll most likely lose some top end.
Old 05-03-2005 | 04:58 PM
gabez28's Avatar
I got a 227/233 on 112 lsa cam so Im thinking the 4000 will get me into the powerband quicker.
Nayr
03-03-2023 08:34 PM
revrider
Cars Wanted
04-05-2016 10:06 AM
95z_28_camaro_4_Ivan
10-03-2015 07:27 PM
colts0455
09-11-2015 06:16 PM
damnyankee36
09-09-2015 07:06 PM
Quick Reply: 4000 Stall and higher guys.
