Airbag Sensor Under Center Counsel
I removed the passenger airbag from the car, but I am leaving the factory steering wheel. I don't want to screw with removing the airbag from the steering wheel so I plan to just leave it there.
My question is this. If I unplug the yellow airbag sensor under the center counsel, will that cause the airbag to false?
Thanks for any help.
IIRC, the passenger side airbag is fairly hefty. It's also a little more difficult to remove. I'm taking both of mine out(already removed all the firing sensors). With the 5-points in the car, all the airbags will do is inflate right in front of my face.
Drtryder
04-22-2015 04:17 PM
