Anyone use the Hurst th350 conversion kit?
I think B&M makes one as well that might be cheaper. these work great if you are using the stock Torq arm and/or have a shorter tailshaft. if you get a 9" tail shaft the stock DS works and you can have a welder put some material on the stock A4 crossmember to work without buying the kit IF you have an aftermarket TA, with the stocker, the kit is very good.
I have spohn TA and 9" tailshaft TH350.
carguyshu
01-22-2017 11:19 AM
Pampered-Z
04-14-2015 05:38 PM
