First Track run
First Track run
I finally made it to the track last night. The weather was 7 degrees Celcius.
Well it was not what I expected I ran consistint 14.4 at 98 Mph. My 60 foot was crap at 2.4. I was on bald street tires so all I did was spin.
My car is a M6 with a B&M short throw shifter, CAI, and a Magnaflow catback. Has 3.42 posi rear.
My question is where should I launch the car. And what tires would you guys think would be a good choice.
What mods do you guys think I need to do to get a low to mid 13 pass.
PS: I really need to work on my 60 foots and also the car has stock suspension other then drop springs. Race weight is whatevera 95 z ways stock.
Thanks for any help.
Re: First Track run
Seems like tires would be #1 on your list. I like Nitto drag radials. Also, practice on launch technique. Each 0.1 reduction in 60-foot means about a 0.15 reduction in ET. So, if you can get your 60-foot to 2.0 sec, then your ET would be in the 13.8 range. Add some headers, and you'd be in the mid 13s, IMO.
BTW, I think 14.4 is pretty good for a first time at the track, with a close-to-stock car and shifting a manual transmission
Re: First Track run
So how do you recomend launching.
Should I slip the clutch a liitle to prevent huge wheel spin.
Would yuo recomend kooks headers with a y-pipe.
And would a tune help me out at all.
Thanks for the help
Thanks for the help
Re: First Track run
Re: First Track run
Sorry, I can't help with launch technique since I have an A4 and I'm still playing around with the best way to launch it.
Kooks headers are very good and very expensive. But I think if you start with a good set of tires and practice launching, you'll be able to use the power you already have. Then, you can decide what mod(s) to do next.
192cobra
01-26-2015 12:12 PM
