Got some drag radials.
Old 04-02-2007 | 09:40 PM
Jared 3870's Avatar
Just as the title says. I was having major traction problems and cutting about 2.1 60' at the track, spinning badly, as well as sticking the back end out during the 1-2 shift.
Best run was a 13.5 at 104, any thoughts on how it'll go on the radials? I'm hoping for low 13s, with a 1.9 60'.
Ideas?
Old 04-02-2007 | 09:42 PM
mdacton's Avatar
did you get some yet? when you first get them heat em good.....and dump it
Old 04-02-2007 | 10:20 PM
blackrat's Avatar
You have any suspension mods? I'm looking through your sig and don't see anything. Stock on new tires I would spin on a 3k clutch dump and got the 60 you see down below 2.4.
Now, with a bit more power and LCAs I would catch too well on new street tires on a 3k drop and bog and managed a 2.2. That time is on the track.
I haven't run DRs at the track with VHT, but compared to regular tires when I take off the on the street, my clutch would give before I had tire spin. If it can do that at 3500 rpms on the street, I'm sure they'll hook just fine on a prepped track. I would worry more about your 10 bolt surviving the trip, especially if you do have stock rear suspension and get wheel hop. Don't launch over 4k too much.
Old 04-02-2007 | 10:55 PM
Joe Brodman's Avatar
GP Moderator
You didn't say what kind of drag radial. There is a HHHUUUUGGGGEEEE difference between Nitto DR's and Mickey Thompson Drag Radials! The MT DR's hook similar to ET Streets, where the Nitto's are more of a tire you can reasonably run on the street.
The BFG's....ehh, ever since the MT's came out, what's the point?
Old 04-02-2007 | 11:01 PM
Spitfire557's Avatar
You're never going to get a real good 60' time if all you are doing is dumping the clutch. Try feathering it out real fast, rather than dumping, it will help you out a LOT.
Old 04-02-2007 | 11:21 PM
zx1216's Avatar
so i have the bfg dr's and have been hearing to come out of the hole at like 1500 and go wot as soon as possible, in the past i have been launching at 4-5k but the best 60 i have cut is a 1.999, how much do you think launching lower would help?
Old 04-02-2007 | 11:53 PM
blackrat's Avatar
yeah, that's how I managed the lowest 2.2. All the dumps were close to 2.3. I was giving an example though to show how well they hooked.
I still suck at finesse though. That and Im too scared at blowing the 10 bolt to leave higher
Old 04-03-2007 | 01:39 AM
Jared 3870's Avatar
They are BFG's that I got used. Don't have a whole lot of life left in them, but they were free, I just mounted them on my stock wheels that were sitting around.
Everyone is talking about clutch dumps but I am an A4, which is also why I am less scared of the 10 bolt blowing out.
I plan on going to the track again the first friday after easter.
Old 04-03-2007 | 08:10 AM
GreenDemon's Avatar
Originally Posted by NavyBlueFanatic
i have bfg all around but, they dont make 275/40/17 tires.
http://www.tirerack.com/tires/tires....4x032&code=yes
my only other choice is M/t or nitto.
BFG makes these as well:
http://www.tirerack.com/tires/Sizes....+Drag+Radial+2
Old 04-03-2007 | 09:20 AM
kick Z tail out's Avatar
I had the ET Street Radials in 255/50/16 and loved them. They stick like glue.
BTW, I'm selling them locally. Only 4 passes on them, still basically brand new. Mounted on salad shooters.
Old 04-03-2007 | 04:00 PM
AutoRoc's Avatar
Low 13's and they shouldn't spin at all. With a stock converter and 3.42's I'd say they'll go 1.85 and you'll go 13.10-13.20's
RUENUF
03-13-2016 03:37 PM
HAWG
09-25-2015 11:41 AM
94ZinEdgewater
09-08-2015 09:55 PM
Quick Reply: Got some drag radials.
