Has anyone used the tire "softener" treatments
My Hoosier Quick Time's are not as soft as they were new (couple years old, but good tread), and I was looking at the tire treatment in Summit, not VHT, but a softener that is supposed to make your tire stickier. Anyone ever try this, and how did you apply it, and what results?
Texlurch - 68 Camaro-LT1 w/Hot Cam, TT & TIC coming soon!
" a little spray never hurt anyone, spank you very much!"
http://camaroz28.cardomain.com/id/texlurch
I used that stuff last year but it didn't make any difference for me, I was using worn out Goodyear RSAs. It makes the tire soft though. I was simply spraying it on but I heard you're supposed to soak the tires in that stuff for some hours to really soften up the tires.
Green 1995 Z28, 6-Speed
Best ET: 12.616 @ 110.33 mph, 1.869 60ft
Race weight: 3430lbs
I have seen an article somewhere that showed it being applied with a paint roller.. may be worth a shot, since new ones are $250 each..
thanks for the response
Thanks for the responses guys! Sounds like it is worth trying out, after I get my turbos done.
It actually hooks fairly well now, but I am looking for "just" that little bit extra!
