LE Heads/cam ET's first nite out!
#17
Thanks guys, I found three problems that were hurting my times also this week. #1 Once I pulled off the driveshaft to swap converters, the yoke was really loose on the rearend (you could rock it back and forth quite a bit) so I tightened it back up where it should have been and pinned the nut, #2 A friend that was at the track told me the car was pulling the driver tire about 6inches higher than the pass. tire so I look under the car and find the swaybar bolt just barely connected. Remember I had some new gears installed and this was first time out with the car. #3 I had taken the opti apart to modify the rotor to keep it from flying apart@7000rpms and evidently overtightened the bolts b/c 2 were stripped and the cap was very loose so I took the opti out and tapped the holes to the next size. So i am going back Sunday to see if i got rid of all the little problems. Later Clint
#18
I had that problem with my Moser aswell. I contacted Ratech about it because its their parts I used with the gear install and was told its a center locking nut whatever that means. It didn't lock for me following their directions. Lots of red loctite and peened it good this time.
#21
Clint I've lost your cell phone number. Please e-mail me your cell number or home number. I have a problem that i'm trying to solve and need your input. Frank Benoit fbenoit@bellsouth.net
#22
#26
