question about finishing the 1/4
Old 09-08-2007 | 08:04 AM
  #16
AL SS590 M6's Avatar
Moderator
Originally Posted by The Engineer
You’re ready for the Bonneville Salt Flats with those tall 2.73 gears!
Nah he switched to an M6 with 3.42s or 3.73s.
Old 09-08-2007 | 01:45 PM
  #17
Capn Pete's Avatar
Almost! Except for that you'd want the 2.56's that were in my '81 Camaro!! How does ~75 MPH in 1st gear sound??? (with a TH350 ... 2.52:1 1st gear). Behind a 6-speed, that would be crazy top-speed potential!
Actually, I'm running 3.90's right now, but I might be putting in a set of 3.23's (they're a more ideal ratio for a couple of the road courses I like to run, due to the potential to run ~135 MPH in 4th gear, vs. only ~120 MPH ..... to avoid shifting to 5th).
Old 09-08-2007 | 02:44 PM
  #18
JakeRobb's Avatar
Super Moderator
Originally Posted by reamo04
alright guys, thanks. I had a local shop tell me that finishing in OD would be fine, but i wasnt sure
On a stock-ish car power-wise, it'll be fine. It's not ideal from a performance standpoint, but you're not going to damage the car.
On a car with lots of power, you can break things by letting it shift into OD -- those gears are often not as strong as the lower gears.
From an ideal performance standpoint, mdacton nailed it: no matter what you're racing, you want to finish at the top of the powerband in your 1:1 gear, whatever that may be.
Old 09-09-2007 | 01:27 PM
  #19
northdakota93z28's Avatar
just wondering what guys with 373s a4s with stock tires and rims what mph is the top of 3rd
with 410s i am at 106 i need to get going like 117 can i do that with tall slicks or will i have to change gears some day.;
Old 09-09-2007 | 01:33 PM
  #20
reamo04's Avatar
heres a great place to figure out your gears
http://www.f-body.org/gears/
4.10s with a 28" tire would put you at 116 at the top of 3rd, 373s with a 26 will put you at 117
Old 09-09-2007 | 01:51 PM
  #21
i need a 28 inch tall tire can i fit that under my stock car.
Old 09-10-2007 | 08:38 AM
  #22
Moderator
Depends upon the stance of the car and the wheel tire choice. My car sits quite high and doesn't squat on launch. I have 15x8 Prostars with a 5.5'' backspacing and run 275-60x15 Hoosier drag radials (which are 28'' tall) and I have no clearance issues at all. No banging, cutting, fender rolling at all.
Old 09-10-2007 | 11:46 AM
  #23
TedH's Avatar
I was a dummy when I fit the 28s under my car for the first time... I was at the track and the first time trial was coming right up and it was a points day and I was in contention for first place...
NEVER do something untried for the first time in a competition setting that you do not absolutely have to do if you actually want to be successful.
Of couse they didn't fit... It took a sharp knife and a little sweat equity but I manually hacked off the bottom front and rear of the outside wheelwells and whacked back the twisted metal supports with a hammer.
Anyway, I made the first time trial, and then got lucky and won the race.
Old 09-10-2007 | 12:37 PM
  #24
reamo04's Avatar
when dealing w/ a 28" tire, it is a VERY good ideal to have fully adjustable LCA's
10-31-2016 11:09 AM
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
jayblev95
Track Kill Stories
01-15-2015 07:48 AM
Collector Car
01-05-2015 10:58 AM
Quick Reply: question about finishing the 1/4
