Solid Roller again..
Ok, just wanted to see if you guys thought that I would still see the 10-12% gain in HP if I use a solid roller cam that has simular stats to my current cam. Below are the #'s.
-Solid roller comp cam- 242/248 585/586 w/1.5s 112lsa
-Hydro roller comp cam- 242/248 576/600 w/1.5's 113lsa
Also, if it matters I'm using 1.6 RRs
Thanks,
Jason
Plates: "Stock 95"
1995 Firebird Formula
O'ring/4bolt 383, GTP Race Ported AFR 210s, Yank TH400, Yank 3800 Stall, Trans Break, Moser 12 Bolt w/ 3.73s, and the usual stuff like Hooker Long Tubes, Holley 58mm TB, Sphon Torque Arm, etc....
Thanks,
Jason
Plates: "Stock 95"
I don't foresee you gaining over 50hp by swapping cams like that. JMO.
Kurtis Tamez
LT4-396.com
97 Z28 LT4-396
94 Firehawk LT1-396
Team NW F-Body
[This message has been edited by KTamez (edited July 25, 2002).]
Kurtis Tamez
LT4-396.com
97 Z28 LT4-396
94 Firehawk LT1-396
Team NW F-Body
I agree it seems strange, but everyone I talked to said that a solid roller will give you 10-12% more power(machine shop and Comp Cams).
Jason
Plates: "Stock 95"
Jason
Plates: "Stock 95"
Henson071
09-21-2015 04:31 PM
