TH-350 and TH-400 Users Lend Me Your Ear
I am getting ready to make the conversion here, and I have a few questions.
Firstly, I know shifters are 99% preference. Are there any that seem to work better if you are keeping the council in the car? How much hogging did you have to do? Pics woudl rock!
Did you have to run braided return lines and scrap all the stock stuff. It certainly appears that way, and want to make sure I know what I'm up against before I crack her open. I still have a few months before I get on this, and it will probably turn into a winter project really.
Thanks in advance for whatever info or pics you can post here.
Nick D'Agostino
1997 Silver Camaro SS
ARE Built 396ci LT1
Moser 9" Rear End
HAL 12 Way Shocks
4L60E Race Built Trans
TNT Twister NO2 System
Best Times To Date
NA Time 12.15@111mph
NO2 Time 10.66@128mph
E-Mail For More Info
Nick D'Agostino
ARE Built 396ci LT1
Moser 9" Rear End
HAL 12 Way Shocks
Best Times To Date
I use a long style tranny cooler and braided steel hose. The best shifter IMO is the turboaction shifter. I can give you a rundown of what is needed and I can sell you all the parts.
281-449-8833
Insanity at its fastest
Worlds Fastest Blown 4th Gen
9.18@ 152
First 9 sec. PROCHARGED F-Body
In Memory of TONY OWEN driver HYDROMANIA
www.madmanandcoracing.com
281-449-8833
9.18@ 152
I use a B&M Pro-Ratchet, mounted in my original M6 console, with no modifications. I even leave the boot on for street driving, and pull it off for the track to make the gear position indicator visible.
http://cjcfo.fbody.com/members/injun...sA/GreenLt.JPG
http://cjcfo.fbody.com/members/injun...B/Shift03a.JPG
Also drove the TurboAction Cheetah in another car, and really liked it.... probably a "future" mod.
I have a cooler with fan tucked up in the front fender (where the typical CAI filter would end up). Braided lines to and from.
http://cjcfo.fbody.com/members/injun.../DCP02963a.jpg
Fred
94 Formula A3+1: 381/TH400+OD/N2O
Advanced Tech Posting Guidelines
Detailed Mod's List
11.513@115.59 on motor; 11.162@127.67, 1.643 60' on a 125-shot. Going with a 275-shot this year
Fred
Detailed Mod's List
Thanks for the replys fellas.
Brian please e-mail me at uthinkso2@comcast.net about what parts I will need
Nick D'Agostino
ARE Built 396ci LT1
Moser 9" Rear End
HAL 12 Way Shocks
Best Times To Date
Nick D'Agostino
ARE Built 396ci LT1
Moser 9" Rear End
HAL 12 Way Shocks
Best Times To Date
Just a thought for the sneaky people, has anyone tried using the stock shifter? Im thinking you could just use the PRND32 and not use the 1st gear. Even put the first gear selector restrictor(whatever it is) back in to keep from trying to go too far. Anyone tried this? I think it would be better to keep that 'stock' look dont you think? If that doesnt work, Ill just order a pro stick, and attempt to make it look semi factory.
Kyle aka Shaggy
Purple 95 Formula
ETFA
12.00@116
Kyle aka Shaggy
Purple 95 Formula
ETFA
12.00@116
Pull the line fittings out of your 4l60 and screw'm into the TH400 - then you can use your stock lines. You may have to tweak the lines a bit, but they will work.
I went with a B&M Megashifter. I hacked the top of the consol lid and screwed the boot down over it.
http://images.cardomain.com/installs.../201570_34.jpg
If I'm playin, I'm sprayin
93 Z28 A3 - w/ Jet Hot coated Hooker LT's and true 3" duals
(hiflow cats, cutouts, and Car Chemistry insert mufflers)
I have the B&M Pro Stick in the stock console with NO cutting (some minor underside grinding,and some grinding on the gate plate).
Check the second link for pictures.
Kyle,the stock shifter would be OK for cruising,but most guys usually run a manual valve body,and the stock shifter has NO positive stops. So if you wanna shift manually,the stocker isnt a good idea.
Dirk
1997 TA A4
11.251@119.3 1.52 60',7.132@95.39 1/8
The RacinLT1
RacinLT1 pic's
Dirk
1997 TA A4
The RacinLT1
RacinLT1 pic's
Fred I like the look of yours very nice. Thats exactly how i was wanting to do my Z. I think it looks good using the factory boot.
I assuming i could mount it the same way in the Z28 Console?
Later
Travis
Later
Travis
I'm using the turbo action shifter. Pics here: http://turbocharged.net/twinturbo/shifter/
I'm also using an external tranny cooler mounted to the front of my intercooler. I'm using -6AN lines. No biggy. There are a few pics here: http://turbocharged.net/twinturbo/Installation10/
Good luck~
...Brady
Twin Turbo 1996 Z28
Sponsored by YearOne
'98 B4C Camaro <--- FOR SALE
Good luck~
...Brady
Twin Turbo 1996 Z28
<font face="Verdana, Arial" size="2">Originally posted by TravProcharged94Z:
Later
Travis</font>
Later
Travis</font>
I am leaning towards the Pro Action shifter right now, but I am stil looking.
Hopefully the tranny will go in next month. Whether or not she makes it to the track remains to be seen.
<font face="Verdana, Arial" size="2">Originally posted by Brady_96Z:
Good luck~
</font>
Good luck~
</font>
