Tire pressure for et streets
What tire pressure and size tires are you running. Also what 60fts. Any info appreciated. Frank95z
1995 Z28,Mystic teal metallic,A4,52TB,pulley,as&m headers,Crane 210/224,Strange 12bolt,Et streets Best 11.66 114.62 1.51 NA
Depends on the power and suspension. My 60's are from 1.58-1.63 depending on weather. I run 15.5 pounds of air. I use 28" x 12.5 x 15" ET Streets. Unless something is severely wrong I always hook.
I know a lot of guys running less air than myself. I try and have as much air in the tire that will hook to reduce rolling resistance at the top end and to help keep my reaction time consistent.
'94 Black Z28, 383, 700R4
1/8 ET: 7.48
1/4 ET: 11.86
1/4 MPH: 112
http://www.downtime.cz28.com.index.html
1/8 ET: 7.48
1/4 ET: 11.86
1/4 MPH: 112
Quoted directly from mickey thompson website (http://www.mickeythompsontires.com)
under tech bulletins
VEHICLE WEIGHT TIRE SIZE AIR PRESSURE
2,500 TO 3,000 UNDER 30" 8 P.S.I. AND UP
2500 to 3000 over 30" 6 psi and up
OVER 3,000 UNDER 30" 16 P.S.I. AND UP
OVER 3,000 OVER 30" 10 P.S.I. AND UP
That is what M/T recommends. Many people think that very low pressure is the way to go, according to M/T it isnt.
1987 GTA- TH400 w/brake, 355, carbed, 11.3:1, TFS twisted wedge heads (non ported), Big Shot NOS, Lunati hyd roller .510/.525 lift 232/242 duration @.050, true dual 3" exhaust, hooker super comp 1 & 3/4" headers, flowmaster 2 chamber mufflers, no tailpipes, 6-pt roll bar strange 12-bolt w/ spool and 33 spline axles, BMR anti-roll bar, BMR LCA relocation brackets, BMR solid rod end panhard bar, PA tubular k-member and a-arms, PA coil over conversion, PA manual rack conversion, Weld Pro-Stars 15X10. Gonna try to fit 29.5X10.5W ET Drags out back, 15X3.5 up front
Best ET last year N/A,Stock suspension, on street tires, T56, stock rear end and 4.56's @ 3515 lbs: 12.44@115.1 (1/4) 8.15@90.5 (1/8)
drive it like you stole it!!
Thanks for the suggestions I'm trying to make some 26x10.5x15's work on my car. And was wanting some starting points thanks again. Frank95z
<font face="Verdana, Arial" size="2">Originally posted by twistedwedge:
</font>
</font>
Rich Krause
'95 Z-28 383: Vortech, nitrous, etc.
AIM: rstevenkrause
Moshbmx1
01-20-2015 03:27 PM
wytblur
08-05-2002 02:03 PM
