When to replace clutch, not sure if needed.
I know clutches tend to slip when they get hot, mine was slipping terribly after driving an hour and a half to the drag strip and making 4 consecutive passes my clutch was slipping terribly. Driving around the street today, it lets out right at the top and chatters a little (always did that), but is still able to spin second and chirp third, but it doesn't feel quite right. I let the clutch cool for about an hour after that bad pass, and went back and ran .2 slower i was just gonna get worse but it started raining. Should i go ahead and replace it?
'96 White Z28 M6-Moser 12-Bolt(Eaton Posi,33-spline axles,4.11's)-Nitto DR's-V6 Rear Springs-B+M Shifter-Fiberglass RamAir hood w/functional Homemade Ramair-QTECH e/cutout-HPPP w/160therm-LT4KM*Weight Reduction, !TB,!MAF*
Dynatech LT's(not installed)
"Let your anger be as a monkey in a pinata, hiding with the candy hoping the children don't break through with a stick" -Master Tang
