Why are my 60's slower?
Just wondering, I am usually pretty good at 60' (well for my car and setup)
Either way I used to run 2.1s, with a decent amount of 2.0s on an open diff.
I know am having a problem braking lower then 2.1s, and I have since installed a takeoff LSD. and it works fine, no noise, leaves 2 tracks all is good.
I was hoping for at least semi consistant 2.0s.
I am running 5-speed, 3.23s. same tires(245/45/16, at the wear bar yokohama ES100s on firebird 5-stars) I used to run a lighter wheel in the front but only a few lbs. total. Now I run the 5-stars all 4 corners at the track.
I have since switched from an open pipe after the CAT to a cutout before the rear axle in, a definite increase in torque and midrange one woudl think that alone woudl increase my 60's. Been running better overall times on average since I changed this.
I was boggin a bit when I tried launching the clutch harder at higher rpms, so I doubt its not enough tire for the car. Example of me boggin on a higher rev, more of a dump on the clutch.
http://www.motorcityoutlaws.com/user...Talmostwon.wmv
My runs from friday night...
at first tried running a bit more tire pressure, since I bogged. But obviously I spun.
36psi in the rears
Car 2k 5-speed camaro v6
-slp lsd
-cutout
-FRA, shaved lid, PVC smooth bellows
-hurst short shifter with lsw speed in stick
-drive belt off
weight reduction
-jack/spare
-rear seat bottoms(bottoms only)
added, a full socket set, jumper cables, 1/4 tank of gas(bit high for me running)
1st run
R/t -0.042 (Redlight, but still close )
60' 2.342 (spun the launch)
330 6.359
1/8 9.696
mph 73.84
1000 12.546
1/4 14.941
mph 94.14
2nd run
R/t 0.132 (sleeping I know)
60' 2.238 (spun again, but not as bad)
330' 6.211
1/8 9.531
mph 74.19
1000 12.370
1/4 14.757
mph 94.51
I dropped the pressure to about 32psi
3rd run
r/t 0.067
60' 2.110 (hooked better)
330 6.064
1/8 9.373
mph 74.43
1000 12.206
1/4 14.591
mph 94.59
4th run
r/t 0.043
60' 2.125(small spin towards top of 1st)
330 6.072
1/8 9.361
mph 74.87
1000 12.180
1/4 14.556
mph 94.82
Those last 2 runs would have been sweet bracket racing runs
DA' was 1200, corrections would have yeilded me 14.373 @ 96.04 but I don't believe in those Though it wasn't the greatest night 75* and 66% humidity.
Any ideas what it might be? I have had off and on clutch problems.
also up for any suggestions(not gonna go drop $$ on a tire)
think a thicker rear sway woudl be worth it, like going to a 21mm over my current stock 17mm rear sway? (I might be able to get a used one local)
Any other ideas, I'd was hoping for 2.0s and maybe chance at a 1.9.
Maybe I should just go up to 3.42s.
36psi in the rears
-slp lsd
-cutout
-drive belt off
weight reduction
-jack/spare
1st run
330 6.359
1/8 9.696
mph 73.84
1000 12.546
1/4 14.941
mph 94.14
2nd run
330' 6.211
1/8 9.531
mph 74.19
1000 12.370
1/4 14.757
mph 94.51
3rd run
r/t 0.067
330 6.064
1/8 9.373
mph 74.43
1000 12.206
1/4 14.591
mph 94.59
4th run
r/t 0.043
330 6.072
1/8 9.361
mph 74.87
1000 12.180
1/4 14.556
mph 94.82
F'n1996Z28SS
08-23-2023 11:19 PM
