12-Bolt question
Originally posted by 97 RedSS
I believe the back braking plates are pointed towards the rear of the car on the LT1 and its the opposite on a LS1..Besides that I think they are the same..
Cody
Cody
i put an Ls1 rear-end in the back of my 95 Z28 and you need to get the Ls1 brakes because the emergency is like a drum brake on the inside of the rotor. You would need Ls1 rotors, emerg brake cables, calipers, emerg. brake cables because they also use different brackets for the emerg brake. But it really isn't that bad if you find an Ls1 rear-end at the right price and i like the emerg brake setup better anyway.
