1994 4l60e in a 1997 z28
Old 03-08-2022 | 08:00 PM
BattleCockBTK's Avatar
Question 1994 4l60e in a 1997 z28
I recently dropped an lt1 from a 1996 in my 1997 30th Z28 just to find out my transmission wouldn't move in forward or reverse gears. The backup lights come on, it stays parked when put in park. Forward or reverse gears act the same as neutral.. though it will only start in park or neutral. I had a friend tow it for me for roughly 350 miles. He used a dolly and didn't remove the driveshaft. So it doesn't work anymore as it was intended. I digress. I found a guy who has a working 4l60e and 2 torque converters all for $120. I know it's not going to be plug and play. Can I just swap out my valve body, internal wire harness and tailshaft and go for it? I have the Haynes manual, but it has 0 on this subject. Any and all help would be greatly appreciated.
Old 03-08-2022 | 08:53 PM
Re: 1994 4l60e in a 1997 z28
This reliable source appears to say you can’t use the 94 4L60E (switched lockup) in place of the 96/97 with pulse width modulated lockup. You could use a 95 with the noted Internal modifications.
4L60E year differences and interchanges.
Moving to “Drivetrain”.
Old 03-09-2022 | 06:39 AM
Thanks Injuneer. I'm sure that this is gonna be a ridiculous question...... can I use the pump off the 94 on my 1997? Money is tighter than a frogs bottom. I don't know if I don't ask. Thanks again Injuneer
Old 03-09-2022 | 09:12 AM
Wish I could help, but details of the workings of auto trans internals are “above my pay grade”. The full manual, reverse pattern (no brake) TH400 in my Formula is the first auto trans I ever had in a performance car. My engine builder had a reliable source and I put my full trust in him.
daddyoisback
Parts Wanted
04-19-2014 09:00 PM
Bobqiont
03-15-2011 01:28 PM
Bersaglieri
03-13-2006 06:21 PM
TransAm9585
07-24-2005 08:54 AM
Kyle@CSS
06-14-2004 08:08 PM
Quick Reply: 1994 4l60e in a 1997 z28
