1996 camaro transmission problem?
Old 06-29-2013 | 08:10 PM
stockman1992's Avatar
Angry 1996 camaro transmission problem?
alright so I recently replaced my transmission now I have a weird knoking noise and squealing from below evrytime it goes into gear it dies and I cant get past fifty once it warms up can anyone shine anylight maybe bolt lose are bad tq something this was my daily now I got to drive a Saturn sw
Old 06-30-2013 | 09:59 AM
12SCNDZ's Avatar
Re: 1996 camaro transmission problem?
Kind of a vague description. Have you tried putting the car up on jackstands and trying to locate the noise? Have you counted the shifts to make certain the transmission is upshifting through all the gears? The squalling could be excessive belt squeel from high RPMs. If the transmission isn't shifting past 2nd gear, it will also cause high RPMs and it won't want to go over 50 very easily.
Frank
Old 06-30-2013 | 10:10 AM
I put it on stqnds and sound likr its comeing from oil pan im guessing a spun rod bearing
Old 06-30-2013 | 10:26 AM
12SCNDZ's Avatar
Good possibilty. Do you have oil pressure?
Frank
globalprojeff
12-06-2014 04:18 PM
globalprojeff
Wheels and Tires
12-06-2014 04:09 PM
JasonD
07-15-2002 02:17 PM
Quick Reply: 1996 camaro transmission problem?
