2000 4L60E with low main pressior problem please help
Old 09-22-2008 | 09:27 PM
vfrgsxr's Avatar
Hello Everyone,
I have a 4l60e that came to me with no reverse and winning, so i dropped the trans and i found that the driving shell splines were stripped and the sprag in the input drum was rolled and the costumer stated that for two months the trans went in and out of 4th gear when hot, so i replaced the sprag, shell and all elect. valves and sensors and over hauled the trans to be safe.
when it was back together it worked like a champ until I drove it for 20 to 30 minutes or so then i could fill 4th gear drop out at light throttle and at low speed going in and out of lockup when worm. i checked the main pressure it is 87=R, 60=P,N, 60=D,3,2,1.
i read somewhere to replace the spring between the TCC regulator and isolator valves with a piece of 5/16” steel tube to correct the lockup, but i didn't not want to just put a band aid on it i would like to repair it. now with the elect. plug disconnected from the trans the pressure are R=205, N=195, D,3,2,1=180, dose any one have any good ideas ? i would appetite any help and Thank You.
Old 09-22-2008 | 09:53 PM
Performabuilt's Avatar
Supporting Vendor
Well the min and max PSI look normal are you sure its not dropping n and out of lockup due to engine missfire ?
Old 09-22-2008 | 10:35 PM
vfrgsxr's Avatar
Yes i am sure it is dropping out of fourth, it drops into tired gear, but only at really light throttle, maybe it a computer problem but theres no codes ? i think the PSI is to low , its great with out the elect. hooked up ?
Old 09-23-2008 | 03:44 PM
Supporting Vendor
The pressure is supposed to be about 60+- at idle and rise to max around 200 at WOT so it does not sound like you have a pressure issue IMO
HectorM52
07-30-2017 11:46 AM
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
jayvar
02-02-2015 10:00 PM
Brake_L8
01-20-2015 09:44 AM
Quick Reply: 2000 4L60E with low main pressior problem please help
