Anyone know of an good transmission additives?
Old 12-10-2005 | 10:22 PM
V8 Slayer's Avatar
Not having any kind of transmission problems at all but just wondering. Anyone recommend any additives to help cool or lubricate or any particular type of oil? Synthetic perhaps?
Old 12-11-2005 | 12:21 AM
n2ceptor's Avatar
Re: Anyone know of an good transmission additives?
Syns like Redline or RP are good..... As for additives, most are just snake oils....
Old 12-11-2005 | 07:08 PM
high c's Avatar
trick shift
Old 12-12-2005 | 11:52 PM
Compstall's Avatar
A4 or M6?
Old 12-13-2005 | 06:22 AM
grasmo's Avatar
amsoil synthetic. no worries. grasmo.
Old 12-13-2005 | 07:38 AM
rskrause's Avatar
Moderator
Generally speaking, a good ATF has everything needed. Additives are a waste of money. I like the "Ford type" ATF for a race car, Dexron (GM) for a street car. The Ford spec stuff seems to shift a little harder. But either should work fine.
Rich
Old 12-13-2005 | 07:58 AM
grasmo's Avatar
i agree. yes conventional oils are much better these days, but the difference is in the molecules between conventional and synthetic. synthetic molecules are round, conventional are elliptical. there are other properties also important but the main thing you want to do is run cooler so i choose round on round (internal parts, brgs. etc.). ford oil has a higher coefficient of friction which means it doesn't allow the clutches to "slip" as much therefore the harder shift. hope this helps. grasmo.
F'n1996Z28SS
08-23-2023 11:19 PM
marineengineer
02-09-2015 03:59 AM
97TA-WS6-Con
02-01-2015 01:01 PM
Fbodfather
25
06-21-2002 04:12 PM
Quick Reply: Anyone know of an good transmission additives?
