Changing the pinion angle on new 12 bolt rear end? Q's
P.s. new 12 bolt went in the car (m6) and the pinion angle is outon the rear end, causing the driveshaft to smack and rub the e. brake line bracket in the tunnel of the underbody. How do you lower the angle of the rear end, ( the pinion angle) Adj. lower control arms? Relocation brackets? The drive shaft is TRASHED! Mabey I can get some pics up soon.
SteveO
SteveO
Re: Changing the pinion angle on new 12 bolt rear end? Q's
Originally Posted by 97FormulaWS-6
The only way to change the pinion angle is with an adjustable torque arm.
Steve
Originally Posted by OBE1 95Z28
IMO something is installed wrong for the angle to be off that far. Double check that the front torque arm mount is installed correctly.
SteveO
SteveO
By chance, did you measure the angle? Most are only off a few degrees, yours sounds like it's off a lot.
Ben T.
Originally Posted by StudyTime
Relocation brackets or adjustable controlling arms won't change pinion angle. I'd double check it's installed correctly. An adjustable torque arm is your best bet once you insure the install is correct.
Ben T.
Ben T.
I have seen them measure the angle on Horse power Tv But I do not own the tool or knowhow to measure the angle? It is way out of wack though. We need to check the front mount of the torque arm.
Good luck with the 12-bolt.
Ben T.
10-31-2016 11:09 AM
oldschool
02-09-2016 09:21 PM
