clutch recomendations
my cars been feeling pretty ****ty latly and ive decided its the clutch, i wanted to know what clutch is recomended for a car that has the usual bolt ons (intake, exsaust ext) and mild cam. i also plan to add a supercharger sometime next year. i was thinking the spec stage 3 but wasent sure because this is the first clutch change my car is going to go through. keep in mind its a daily driver but i only drive about 5-10 miles a day. thanks for your opinions.
oh yea, and if theres a site that sells clutch kits for cheap, the url would be much apprieciated.
complete mod list:
Cam- 221/227 duration .542"/.560", 114lsa
Pro-Magnum Rocker Arms
612 Valve Srings
138 Ultra Light Weight Chromoly Retainers
391 Hardened Valve Locks
720H Hardened Pushrods
Cloyes True Double Roller
PCM tuned by http://www.pcmforless.com
Adjustable Timing Chain Set
Electric waterpump
Magnum R lifters
pro5.0 Shifter
Flowmaster 3' catback
SLP CAI
MSD wires
NGK tr6 cold plugs
de-screened and ported MAF
!tb bypass
manual fan switch
!cags disable
1le elbow
complete mod list:
612 Valve Srings
Electric waterpump
Magnum R lifters
pro5.0 Shifter
SLP CAI
MSD wires
NGK tr6 cold plugs
!tb bypass
manual fan switch
!cags disable
1le elbow
Re: clutch recomendations
I have the McLeod Street Twin and I would highly recommend it. It's a lil pricey, but if you plan on having it stroked out or adding a supercharger or turbo'ing it or a large shot of Nitrous, to me, it would be the only choice. It can handle 1,100 Foot Lbs. Torque without slipping. The kit is very complete. Includes new master cylinder, flywheel, both clutch disks, spacer plate, new bolts, even a fist full of bumperstickers (not sure who would wanna "gauk" up your fbody with stickers but you never know.).
During the first 500 miles it grabs a lil more agressivly than the stock one. If your clutch is slipping really bad and you change to this clutch, you'll see how much gripping power this clutch has. After the 500 mile break-in period, it drives just as stock as the orginal clutch. Its not as "HEAVY" as most people think or say. I'm 6'3" and thin as a rail, in other words no "strong" guy and its just as easy to press the clutch pedal as the stocker was. It doesn't engage HARSH as everyone says either. During the first 500 mile break in period, it has a sort of on/off feel but after break in, you can ride/slip it no problem.
Don't listen to people that don't have this clutch and make comments on it. This clutch is used in my 97 t/a that sees about 300 miles per week. This car is my daily driver.
If you want to see how it takes off, view this video of my SLP Loudmouth. In this video, I show you the outside of the car with the Loudmouth, then I take u on a drive inside the car with the loudmouth, notice how easy I can take off with the McLeod clutch. No "ON and OFF" feeling or jerking whatsoever.
http://www.mattiecradduck.com/slploudmouth.wmv
