conversion
conversion
if you do a conversion from 6-sped to automatic what all do i have to change, besides remove the 6 speed petal ect...and what do you do ith the switch to release the key in the ignition? will it even be affected by this?
Re: conversion
you need an A4 Wire harness and either re-flash the PCM or get an A4 one to run the trans, and yes you need to re-route the cluthc pedal safety switch to the auto shifter PNP (park neutral position) switch. Try and find a tuner on here from TX to help you out..
Henson071
12-30-2015 09:55 PM
tdigger9899
09-07-2015 10:56 AM
