Differential cover
Old 10-30-2011 | 08:31 PM
97z28k&N's Avatar
Exclamation Differential cover
Do you need to move the sway bar in order to remove the bottom bolts of the differential cover?
-Thanks
Old 10-30-2011 | 09:12 PM
Re: Differential cover
No. Depending on how you have the car jacked up, the position of the bar will change and allow you access (if it is even in the way).
Old 10-30-2011 | 09:31 PM
97z28k&N's Avatar
So how will it be if I back the car onto steel ramps?
Old 10-30-2011 | 10:07 PM
Rij1's Avatar
The same way as it sits all the time. the axel has to move away from the body of the car for the sway bar to move its self.
Old 10-30-2011 | 10:17 PM
97z28k&N's Avatar
Should I not even worry about the sway bar then?
Old 10-30-2011 | 10:37 PM
Rij1's Avatar
No. If you have a jack & jack stands or even block of wood use them. raise the rear end place your j stands then use the jack to move the differential up and down.
Old 10-31-2011 | 09:20 AM
97z28k&N's Avatar
So to simply, I should have no complications with my ramps? Those are all I have.
Old 10-31-2011 | 12:29 PM
Rij1's Avatar
Try to use them and see if you can use a box wrench to get the last bolts out. You dont have a jack in the trunck?
Old 10-31-2011 | 05:14 PM
Try it. If you find the sway bar is in the way, its simply a matter of loosening the two U-bolts that hold the sway bar mounts to the axle housing. Or undo the end links and raise the ends of the bar to pivot the bar downwards, away from the cover.
I watched a guy in a shop pull the entire differential out of my rear axle assembly without touching the sway bar..... but that was a 12-bolt, so the clearances may have been different.
Old 10-31-2011 | 06:55 PM
97z28k&N's Avatar
Cool Re: Differential cover
Thanks! I ordered a new Dorman differential cover with a gasket, would you recommend me still use sealant on the casing when I bolt it back up?
jackpawt883
07-31-2015 08:15 AM
whitehooptie
07-22-2015 10:25 PM
CARiD
07-07-2015 08:19 AM
SergheiS
07-05-2015 03:27 AM
Quick Reply: Differential cover
