How Do I Tell Which Gears My Z28 Has Out Back?
go look at the code list on the end of the door. get the GUx code (code will be GU then a single digit).
i *think* the following codes mean the following gears (not sure, but i'm sure someone will correct me if i'm wrong):
GU2: 2.something
GU3: 3.23
GU5: 3.42
GU2: 2.something
GU3: 3.23
GU5: 3.42
GU2: 2.something
GU3: 3.23
GU5: 3.42
GU2: 2.something
GU3: 3.23
GU5: 3.42
Originally posted by StormSigma
Thanks, I'll go check right now. Also a good question, which are the more desirable ones to have?
thanks 99blackSS, GU2 is 2.73
GU2: 2.73
GU2: 2.73
Don't remember where that is right now, though... I'm sure somebody will pitch in with either the link or the formula how to do it.
This might be of help, too... http://www.f-body.org/gears/
TS
GU2: 2.something
GU3: 3.23
GU5: 3.42
GU2: 2.something
GU3: 3.23
GU5: 3.42
Originally posted by mullettour
A4's didn't come from the factory with 3.42 gear ratio. Only 2.73 or 3.23. The 3.42 was in the m6.
Ok we were ALL wrong. I just called the local Chevy dealer. I have the 3.23 rear end. The code for that is GU5, the 3.42 gears are actually GU6.
Oh, and the Positrack option is designated by the G80 code. I have that too.
It must be true ... it's written down on paper .
Oh BTW it's the factory manual .
I like my 2.73's i can almost pull a 2.0 60ft (think it's like 2.045) with stock drivetrain and stock suspension, with the few mods listed below, plus i get better gas milage and can go 160+mph<<<<<<<like you need it...lol
ChrisFrez
12-15-2014 03:09 PM
07-04-2005 05:00 PM
1LEThumper
07-14-2003 12:45 PM
