OBD1..can I run a 3000+ stall?? Whats the odds
Old 07-06-2004, 05:47 PM
Yby4n95Z's Avatar
Whats the odds from what you guys have seen, on a 3000 or higher stall working with an OBD1 setup. I taked with ION and he said there was software available but I forgot to ask what software ( any ideas while, I'm inquiring ) and he mentioned with the software I have a 75/25 chance of it working. I have my eye on a 3200 stall and don't want to pay to have this installed, only to find out it isn't going to work.
Is 3200 stall getting out of "streetable" range? Last car had a 2500 stall and it worked well.
Thank guys
Adam
Yby4n95Z is offline
Old 07-06-2004, 07:06 PM
95 Mystic TA's Avatar
<-----OBD1 and 3200 stall on the daily and lovin' it. I believe it's 3500 and up and I have't heard of anyone having a prob with 3200 or smaller. That's not so say there aren't those who have had it.
95 Mystic TA is offline
Old 07-06-2004, 07:26 PM
Jay-Roll's Avatar
Most people say it's 3000rpm stall that's the limit. Anything higher is asking for trouble. There are quite a few people who have been trouble free going higher though. It's up to you if you wanna risk it. BTW I have a 3000rpm stall and it works great(95' Z).
Jay-Roll is offline
Old 07-06-2004, 08:45 PM
Yby4n95Z's Avatar
Thanks again this helps greatly.
Adam
More suggestions welcomed!!
Yby4n95Z is offline
Old 07-06-2004, 09:14 PM
RamAir95TA's Avatar
I ran into the problem with my Midwest 3600, unfortunately. Bryan @ PCMforless.com fixed it for me though. It's not fun when it happens to you at the strip.
RamAir95TA is offline
Old 07-06-2004, 09:18 PM
Yby4n95Z's Avatar
SOOOO what your saying is there is a good chance that I can have my computer tuned to like the stall
Adam
Yby4n95Z is offline
Old 07-06-2004, 09:27 PM
Adam
Of course. Bryan at PCMforLess has been writing tunes to accomodate for the higher stall for awhile now.
Old 07-06-2004, 10:49 PM
neil350's Avatar
Glad I have a 93, I could put a 5K stall in it and the ECM could care less. I thought the problem with OBDI 94-95 cars was that the computer cant process the stall fast enough?
neil350 is offline
Old 07-06-2004, 10:52 PM
Dave Feerst's Avatar
I run a SY3500 Yank with no problems. That is their 3500 designed to hook up with drag radials
their ST3500 (the stall designed to be used with slicks) may give you that problem.
Dave Feerst is offline
Old 07-07-2004, 12:32 AM
94 TA TT2S's Avatar
What Joe (RamAir95TA) said
Yank SS3600 here.....Bryan fixed it for me
94 TA TT2S is offline
Old 07-07-2004, 01:49 AM
RED95LT1Z28's Avatar
I had a 3200 in my car for about a couple of months and it was fine but i decided it was way tooo loose for the car so i went to a 2800 but i had no probs with the 3200 for as long as i had it in my car.
RED95LT1Z28 is offline
Old 07-13-2004, 12:03 AM
Someone told me when i put the 3200 in my car this torque management thing in the computer will come on and you will get a SES light.....what exactly is the tranny doing.
Old 07-14-2004, 03:05 AM
stik6shift93's Avatar
Pcmforless.com can take care of it for you. A buddy of mine got away with a 3200 for about a month but then took it to the track a few times and the high stall problem showed up. A 3200 is not bad for a daily driver I used to run a 3000 stall in my 97z and didn't really notice a reduction in gas mileage as long as i kept my foot out of it. Once you hit 45mph cruising the lockup clutch will take all the slipage out of the converter so it isn't bad at all.
stik6shift93 is offline
Old 07-14-2004, 03:06 AM
I almost forgot you'll definetly need a set of sticky tires, i ran nitto 555r's and I'd recommend. If you have a street tire you'll be all over the place when you launch.
Old 07-14-2004, 01:36 PM
Don't be a sissy go with the ET streets
Quick Reply: OBD1..can I run a 3000+ stall?? Whats the odds
